Calculate / doors
hello Guys,
Is it possible to exclude a door from the calculated door schedule?
Thx
13 REPLIES 13
Djordje
gobel wrote:
hello Guys,
Thx
Yes.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Stress Co_
Djordje wrote:
Yes.
Djordje is right.
If your next questions is "How do I exclude a door from the Calculated door schedule?" .... then try this:
Give the door(s) you want to exclude from the schedule an "Element ID" of NIS (not in schecule) and then set that "element ID" as an excluded criteria.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Scott Bulmer
Marc,
I have tried to locate the Element ID from the additional parameters DB without luck, and further tried excluding doors using the zone name without luck. If you have time can you please tell me what I'm doing wrong?
Thanks,
Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
Stress Co_
Scott:
This is what I did.....
Changed ID name... Here or Here
Stress Co_
Then I set my schedule like this:....
Stress Co_
Ohh, yea.... I have a foot in 9 and a little toe in 10 .... this was all done in AC9.
Scott Bulmer
Thanks Marc,
I see in the Criteria section of your Scheme Settings for the Door Schedule you have added the parameter 'Element ID', and that you're on a Mac. My settings on the PC are a little different, but I cannot seem to locate the Element ID parameter from the Additional Parameters Dialog Box (when selecting any door) in the Criteria section. The Element ID does show up in the lower portion of the Settings DB under General, but that is for listing only in the Fields section of the Scheme Settings. Where did you find the Element ID for Criteria and not Fields?
Thanks,
Scott
Stress Co_
Thanks,
Scott
Is this what you mean?..... the pull down menu?
Scott Bulmer
Hey Marc,
Our Scheme Settings DB's are different. BTW, your's looks much nicer and seems to be more user friendly. Unless I'm missing something, I don't think AC10 on a PC can do what you have posted for AC9 on a Mac. I'm starting to get a little disturbed.
Thanks & let me know if I'm way off base.
Scott
