Can I import 3D model from autocad?
Hi to all users..
Is it possibile to import a 3d model from autocad to archicad9????
[Topic title edited by moderator to be more descriptive. Original title "imoprt 3d model from autocad is possibile?"]
2 REPLIES 2
The only way (AFAIK) is to open the DWG as a library part. The ArchiCAD building model requires parametric data which the DWG lacks. As a library part the DWG has the minimal parametrics (location, scale, etc.) which allow it to exist within the ArchiCAD model.
Ben Odonnell
AutoCAD users can export their models as .3DS files. You can then, with help of the 3DS in add-on, import AutoCAD models into ArchiCAD.
If you don't have the 3DS in add-on already loaded you will find it in the "Goodies" folder in your ArchiCAD directory.
The models will be converted into GDL objects.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
