Can't edit any property value in Interactive Schedules
Please help!
Up to Archicad 22 i could edit strigs values right in schedules. But in A22 it locks!
The same file with identical settings!
I found, that the problem appears, if add any Criteria except "Type" to scheme! Why?
Daniel Kovacs
I took a look at this issue, and it seems like it is a bug. You should be able to edit those values in AC22 as well. I let the developers know, and they hope to fix this in an update (it will be in the release note as fix #262070).
Sorry about the inconvenience, I hope this doesn't hinder your project too much until the fix arrives.
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
