Cannot import 3D DWG file from AutoCad 2012.
Chazz
I can see the 3D data in other apps (eDrawings, AutoCad WS, ProgeCAD Viewer DWG) and I can import the file as a 2D drawing but I cannot get the 3D data across.
Any insights?
Here's the file:
https://docs.google.com/open?id=0B5wwAtvpmHgrc2tQQVpOZW90Z1U
Nattering nabob of negativism
7 REPLIES 7
Erika Epstein
Did you try saving it as a 3D dwg?
Or merging the file?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Chazz
Definitely tried the Merge method and get a message saying "No Elements Were Created"
I'm not the author of the file so cannot "save it as a 3D dwg". But i know it is 3D because I can see it in dwg viewer apps.
Erika Epstein
Chazz,
Try bringing in the file as a library part.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Erika Epstein
I'm having trouble downloading the file from both firefox and safari.
Do you want to email it to me?
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Erika Epstein
Chazz,
I did get it downloaded and opened it in 15. There are about a dozen polygon error messages that I clicked to ignore.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Chazz
Thanks for all your help Erika. This remains a mystery to me. I did a New and Rest, even installed a fresh version of AC15 without any add-ons to test. Nothing worked. I even asked the author of the file to provide a few different formats (DXF, DXF Block). Exasperating.
Hi Chazz,
I managed to open the file successfully using the 'File'> 'Libraries & Objects'> 'Open Object' method, and convert it to a library part with no errors.
The 'trick' was in the dwg translator. Under the 'Open Extras' section there is a checkbox labelled 'Convert to GDL Object'. With this ticked and the correct unit in 'Drawing Unit' selected (inches seemed to work for me) it created a library part.
Be aware that it has 186,000 polygons and does take some time to convert and save. It even crashed ArchiCAD once when converting, but I think the machine ran out of memory (32bit fail! )
Also note the resulting library part is nearly 39MB in size!
Hope that helps.
