Circumference of Slab in Schedule
If I click on a slab, I can see a circumference in the Element Information palette. In a schedule, I do not see anywhere to select the circumference as a field. Is this possible? I would also like this number in a label but also don't see it as an available field.
Kris
1 Solution
Under General parameters, schedule the Floor Plan Perimeter. Interesting that Element Info uses the word "Circumference" vs "Perimeter".
Go to post
3 Replies 3
I looked through all the properties several times and didn't see this. Looked for both circumference and perimeter. Thanks for the pointer.
I also see that I could have used the search as the top of the properties list. Lots to learn.
