Ahmed_K
Mentor
Classification translation
i want to translate the Uniformat classification downladed from Archicad website,
the xml file, once loaded in excel, it can't be saved back as an xml to load it ino archicad,
Is there a way to translate it ? or workaround ?
Note : I have an excel sheet with only ID + translated classifications
Thanks
Archicad 27
Windows 11 professional
17 Replies 17
Try editing the XML file with a dedicated XML editor, like Notepad++ (it is free). Then, if you save changes, the XML files should still have the same format.
Ahmed_K
Mentor
i already tried this, , the problem is : how to translate only the classification names,
Archicad 27
Well, if you post a concrete example of what you are trying to achieve, I can take a look at it to see if I can find a way of doing it.
A screenshot or two would also be helpful.
Ahmed_K
Mentor
This Is the classification system, all in English, ( Masterfomat )
To translate names in frensh, to do this on archicad is a waste of time
translating the file in a XML editor will also translate commands
Archicad 27
OK, and what are you trying to do?
Ahmed_K
Mentor
translating classification names, from english to frensh
Archicad 27
Ahmed_K
Mentor
open file in excel => translate => save as XMl , don't work too
Archicad 27
And what if you simply save the XML under another name, and change the texts in the XML itself?
Looking at the XML, I would assume the simply changing the following
<Name>Procurement and Contracting Requirements</Name>
to
<Name>French Translation Text</Name>
should work.
Actually, I was curious so I tried it. I just modified the XML file in Notepad++, saved and I could import it into the Classification Manager Dialog without any problems.
As you can see, I have translated a few English entries into Hungarian and they are correctly displayed.
