Srinivas
Component List Error
I am working with a project on ArchiCAD 11, when I try to generate the lumber pack component list for the wall framing that was created using the "Wall Framing" addon that comes with ArchiCAD, it is displaying me with an error message as attached, I tried downloading the AC 10 LCF and also the AC 10 subset library from Graphisoft's website and added it to the project library, but still the problem persist, can anyone shed some light on why this error is coming and a way to get rid of this.
Thanks in advance.
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
3 Replies 3
You should open that GSM file for editing.
Go to its Property Script and find the text "AC_10_INT".
Try to modify it to "AC_11_INT" and save it.
See if that handles it.
Srinivas
Thanks Laszlo,
I opened the object but haven't found anything like AC_10_Int in the library part, do I have to open the "Lumber Pack" component list to see if it is there, can you let me know how to open it.
Thanks in advance.
ArchiCAD Service
Mac, Windows 11
I don't have that GSM file but if you open the file "LumberComponents_11.gsm" for editing using the File\Libraries and Objects\Open Objects command you will see soemthing like on the attached image.
Click to see the Property Script and there should be some text saying "AC_10_INT". That you should change to "AC_11_INT".
OR, upload this GSM file here in a zip and I take a look at it.
