Composite Wall Schedule/Scheme with composite skins shown
adzik
Hello,
I'm creating a wall scheme for an apartment building, with lots of different composite walls. I've managed to make it show all the composites layers, but is it possible make it show each layers skin (fill) as well next to its name?
Also, is it possible to make the schedule show only those composite walls on a specific storey?
TIA.
Running ArchiCAD 23 INT.
11 REPLIES 11
Not that I am aware of - you can only show an image of the entire composite.
Yes, in the criteria just add a criteria for the storey - positioning > home storey.
adzik
"you can only show an image of the entire composite."
Care to elaborate? like .jpg or did I misunderstood?
about storeys. I've already added the home storey criteria, but the schedule still shows composites that arent present on the specified storey.
Just the 2D or section preview in the schedule - you said you were already doing this?
So storey-wise you have a setting like this in the criteria?
adzik
Yes.
Well that works for me and schedules the walls only in that particular storey.
Maybe if you can show a screen shot of your schedule scheme settings we might be able to spot the problem.
adzik
I'm not at the office right now, but I'll send the screencap later on.
But for info - on some storeys the walls are shown correctly (i.e. only those that need to be shown) so I'm guessing I probably have some walls whose home storey is linked to the wrong storey... and if thats the case I can only blame myself for negligence
I might be looking for the same solution? Here is my schedule below. I would like the 3d axon to show fills too. Any ideas? Cheers - Jakub
Hatches and colours are all controlled in the Graphic Overrides.
So you will need to set up a special GO for schedules and then apply that to all the schedule views.
