Computed Fields in Schedules
how can I add computed fields to schedules in ArchiCAD?
In Revit I can add custom fields with calculated values. Is there a similar functionality in ArchiCAD?
Thanks, J.
1 Reply 1
Eduardo Rolon
You can't. This is one thing were Rvt is better than AC. You can sum all the items in a column but that's about it.
The workaround is to export to Excel, creare a PDF from the sheet and import the PDF in AC.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
