NateLumen
Label that uses "custom text" field from schedule?
I have a number of beams that I am scheduling as duct penetrations. In the schedule I have added about 8 "custom text" fields. Are these now associated with these elements such that I can create a label in plan or section that uses autotext to show the custom text from the schedule? Does that make sense?
Nate Lumen
Apple MacBook Pro M1
Archicad 27-29
1 Solution
CosminF
To my knowledge, no. You can't recall the info placed in a custom text in schedule in a text label as that custom text isn't "embedded" into the object.
A better way to achieve this would be through the use of properties:
 https://support.graphisoft.com/hc/en-us/articles/30314384468881-How-to-add-Custom-Text-in-a-Schedule
Fastest way that I can think of, to transfer the data from your already-made custom texts would be to define 8 properties, and schedule them along your custom texts and just copy-paste from one cell to the other.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Go to post
3 Replies 3
CosminF
Patrick M
Ace
I've long switched from custom text fields to just using properties
JeffH
properties would be the workflow I would utilize, as well
AC24 / AC26 / AC27
Win10
