_Salmon
Convert degrees to percent
i'm trying to convert from degrees to percent using this formula: "percent = tan (angle) x 100"
why doesn`t work?
thanks
Since AC6
Win10pro / Intel Xeon E5-1650v4 / 128Gb DDR4 2400 MHz ECC REG / NVIDIA GeForce GTX 1080 / SSD Toshiba 512GB M.2
8 Replies 8
If 0° = 0% and 90° = 100%, then isn't it just a straight relationship - nothing to do with TAN?
(angle * 100) / 90 should give you the %
i.e. (45° * 100) / 90 = 50
runxel
That is a common misconception, but in reality of course 100% inclination equals 45°.
(It's easier to remember, if you know, what x% inclination even means: after 100 meters going "flat", how many meters did the slope go up? (= imagine a right-angled triangle) If the answer is "100", then this triangle obviously has 45° angle)
So, if all you got is the angle, then the inclination in percent is indeed the TAN of the angle * 100.
What's not working on the other side is the additional "STRCALUNIT".
Just use
"TAN ( {the Property of incl.} ) * 100"
and you're good to go.
_Salmon
thanks for your help!
But which expression i have to use to publish the % result in a string?
The error is still there
Since AC6
_Salmon
Ok. Solved!
So now i'm trying to quit those decimals in the pipe diameter.
Any idea?
Since AC6
runxel
USe SPLITLEFT and with the comma as the text where to split.
Thanks runxel.
You can tell I don't use % for slopes.
_Salmon
Done! Thanks Runxel
I started using archicad 21 years ago thanks to people like you.
I hope graphisoft takes into account the importance of the help service we need in the forum
Since AC6
TJ Admin
If you are still looking? This is the correct string Formula. Meant to label Roof 'Pitch' "Auto Text":
CONCAT ( STR ( TAN ( {Property:Roof/Pitch} ) * 100; 2 ); "%" )
