Here is what you should do as the first step: install an IFC Model Viewer application like Solibri Model Viewer or Tekla BIMSight, and open the IFC file exported from Revit there.
Check if those parameters are available in the IFC file. They may not have been exported from Revit in the first place.
If they are not present in the IFC file then you should get it exported from Revit properly.
