‎2005-09-22 11:01 PM
‎2005-09-23 12:55 AM
‎2005-09-23 03:37 AM
‎2005-09-23 03:58 AM
Adalbert wrote:Have you tried the Check For Duplicates add-on that come with Archicad?
Q: Is there a way of eliminating duble placed elements?
‎2005-09-23 01:58 PM
Michele wrote:Interesting problem. I would think, if you are trying to get lin.ft. of base cabinets it would be better to extract the info from a separate "countertop" object. I personally place all cabinets without the counter top and place a separate countertop object across the top of all of them.
I want to be able to use objects for base cabinets but also be able to have archicad calculate them as linear ft and add all base cabinets together. AS of now, I have to get a list of cabinets ... (3) 3 ft base cabinets, (1) 2.5 ft base cabinets and then add them together in excel. Is there any way to use objects but to get them to add in the same list scheme I use for slabs and walls? And get all the base cabinets to add all together?
Thanks in advance,
Michele
