Rick wrote:
So, my question is can the current scheduling functions with expressions replace the Listing abilities in full?
I would say that if you can create a calculation in your list with property objects, then you can do the same with properties and expressions.
With studs, it is still not as good a modelling every stud and counting them, but you can create an expression that divides the length of a stud wall and add one or 2 extra if needed.
Not that I have personally done this, but from what I have experimented with it should be possible.
Likewise you could work out the number of sheets for cladding or the number of bricks in a wall.
But you will never really know until you give it a try.
For now at least you can still use the list schemes.
