Curtain wall objects in Interactive Window Schedule?
Does anybody know how to include curtain wall objects (AC-12) in an interactive window schedule? Thank you!
In the Project Map of the Navigator, right-click on Schedule and select Scheme Settings, which will take you to the Scheme Settings Dialog.
Create a New Scheme and in the Criteria panel use the Element Type criterion and select Curtain Wall for Value. Then set the rest of the Criteria and Fields panels. Further info is included in the Help files.
Thank you!
I've found it difficult to combine both regular windows and curtain walls in the same schedule due to different parameters. So I ended up creating two separate schedules.
