2024 Technology Preview Program
Custom Curtain Wall Panel - ArchiCAD 22
I can't seem to pull any information from a custom CW Panel into a schedule. Really only need quantities but an elevation view (3D Front) would be nice as well. Also when I go to the 'Library Part Parameters' half of the criteria comes up as another language, Japanese I believe..
Has anybody had success in this?
1 REPLY 1
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Thank you for sharing the issue to the forum!
Unfortunately, since this is a custom panel, I'm not sure how this object works, or which parameters are available to be listed in Schedule. Is it possible for you to share the object for a closer look? Thank you very much and I look forward to hearing from you!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
