Thank you for sharing the issue to the forum!
Unfortunately, since this is a custom panel, I'm not sure how this object works, or which parameters are available to be listed in Schedule. Is it possible for you to share the object for a closer look? Thank you very much and I look forward to hearing from you!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
