Showing results forΒ
Search instead forΒ
Did you mean:Β
Search instead forΒ
Did you mean:Β
DWF Sharing Issues
I printed DWFs in Archicad 11 using the Autodesk DWF writer. When viewed, using Autodesk design review, everything looks as it should. So, I sent it to consultants. Now every consultant is saying they are having text issues when viewing the DWF. They say that the text is on top of each other and some of the words are cut off. I even had them resave the DWF and send it back to me and the DWF still looks good on my end. To my knowledge they are using design review to view the dwfs as well. Does anyone know what is going on and what would be causing this?
1 Reply 1
Eduardo Rolon
They might not have the font you used.
Eduardo RolΓ³n AIA NCARB
AC29 US/INT -> AC08
