DWG drawing - how to use?
I have never used a DWG drawing before, but now I got one...
How can I get the drawing in 3D?
How do I use ArchiCAD objects in the file? Just as normal?
David Larrew
You will need to open the 3D AutoCAD file as an Object in ArchiCAD to be able to see and use the 3D entities.
"File>Libraries and Objects>Open Object..." from the pull-down menu. Then select ".DWG" file type.
David Larrew, AIA, GDLA, GSRC
Architectural Technology Specialist
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
