2006-06-15 08:49 PM
2006-06-15 09:35 PM
2006-06-16 04:04 AM
2006-06-16 07:11 AM
another Moderator
2006-06-16 11:49 AM
Eric wrote:I am so sorry for beeing ignorant in so many important things, but...:
You can try zipping it and then it might be small enough to post. If not, post a screenshot of what you see in AC and what you see in edrawings viewer.
Are there any xrefs in the dwg?
The hint Thomas gave is a good one. When you think there is nothing there try CTRL-A to select all elements. Do you see anything highlighted? This happens often with Civil Engineering drawings in my experience due to the way they use coordinates.
2006-06-16 12:24 PM
Jaime wrote:Whole screen: Command (Apple)-shift-3
—how does one make a screenshot in MacOsX 3.9?
2006-06-16 04:25 PM
"Eric Batte" wrote:
You can try zipping it and then it might be small enough to post. If not, post a screenshot of what you see in AC and what you see in edrawings viewer.]
I am posting a screenshot of Archicad (empty, no lines).
There are no visible layers on the Archicad file (with the exception the Archicad layer).
Jaime Neto
Archicad 9.0.0 | PlotMaker 9.0.0 | PowerBook G4, 1 GB Ram
2006-06-16 04:52 PM
another Moderator
2006-06-16 06:04 PM
Jaime wrote:Mysterious.
2006-06-20 09:38 PM
Thomas wrote:Ok! Thank you all for your kind replies.Jaime wrote:Mysterious.
- have you succeeded in importing any DWGs any time before?
- Check with the sender that the file isn't saved in a later Autocad DWG version than 2004. I don't think 2006 works in AC9.
(...) If nothing works, you need professional support. Contact your reseller.
