Database Query Command in 21
poco2013
Mentor
Not sure if this is the correct forum for this-- BUT??
In Archicad 21, trying to find the Database SQL "Query" Command. This menu command was in all previous versions of Archicad under the Calculate menu structure (theme) - #16. Wondering if it was removed, relocated or renamed??
Gerry
SQL is no longer officially supported.
http://archicad-talk.graphisoft.com/viewtopic.php?t=57029
It seems the 'Query' command is no longer in the work environment although I believe some SQL does still work.
I may be wrong about that as I don't use it.
So I don't know how you would invoke it now if you can at all.
I just checked a bit further.
The 'Query' command was available in version 20 but has been removed from the Work Environment in version 21.
poco2013
Mentor
Thanks for the response.
Actually I never used it for anything practical , but did use it as a learning tool to investigate and understand Archicad's database organization and available attributes.
Hopefully, it was just removed because their going to come up with something better. I'll miss it as a quick learn.
Archicad seems to be going the direction of developing properties for elements rather than one massive catchall database -- Which I would also prefer, but we need a better method to program and control properties outside of a database or the API. Wishes?? Particularly if the SQL query path is now gone.??
Gerry
