Curtain Wall Overall Shape and Adjustment of Individual Members
I have two queries relating to curtain walls, I could do two separate posts, but they are somewhat related.
First Query.
I've used the Redefine Boundary From Fill command, however I now need to alter that boundary.
For the life of me I can't find how to redefine.
I have tried; clear all connections, right-click menu, design menu, tried using another fill, and dialogue settings to no avail.
Second Query.
I want to trim only the orange members so the tops intersect the red curve, and the bottoms intersect the blue curve.
Trimming and extend options aren't available. I have tried to manually stretch each one, but you only appear to be able move, not alter length.
The hope is to get something that looks like this (example using columns).
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
runxel
Using another fill and the command again works fine for me...
You can also edit the boundary in the edit mode of the CW. Just make sure you go into the scheme grid.
You can then either make adjustments to the boundary there, or you draw something new. See also https://helpcenter.graphisoft.com/user-guide/128176/
The second thing only works with two different CWs. Or you would go into there and adjust every single frame. (not a real option tho)
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
