I use Archicad and Robot.
I didn't download the addon for a better connection to revit product yet.
My experience is "so ans so".
I modeled int Archicad some reinforced concrete structures and exported towards robot via IFC. The result is not reasy to be used in robot, and what you get in robot needs to be adjusted. In fact, for example, slabs are translated as panels in robot laying at th level of their center ( a 30cm thick slab will lay 15cm lower than its top surface ... And so on). The same for pillars and beams. They are translated as linear member in their axis. So all the connections should be checked and modeled again. Equally for the walls. Junctions of the walls a to be checked. Obviously no loads, no constraints, no combinations of loads .... Nothing.
But an experienced robot user can adjust and tune the model coming from Archicad very quickly (robot is fantastic).
Sure we Archicad+Robot users need some (specific?) tool to go and come back from the two software a smoothly ....
I didn't study the problem very deep, but I want to do. If I have some news, I will share.
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
