Door Frame Neck width in door schedule
Hi, and thanks in advance for any help.
I've got a nice door schedule going right now, I've customized it quite a bit to get the information I need, and Archicad is performing well in that respect.
The one piece of information I can't seem to get linked to my schedule correctly is the Neck width of my aluminum hollow metal door frames.
I've found a dynamic attribute called "frame thickness" that I can add to my schedule, but it just reads 4" by default for all doors in my project regardless of the size of the wall they are located in.
Within the individual door properties, I can't seem to find a place where the neck width is defined, but it should be dynamic depending on the thickness of the wall it is in.
1 REPLY 1
ares997
Is the variable in the object attributes? Would you have to define it the GDL script then reference that information in the attributes?
Archicad 25 (5005), Windows 11, AMD RYZEN 7 3900 (64 GB RAM)
