DoorBuilder: Door with single window?
I've got this apparently bizarre requirement for DoorBuilder: a metal door with a single window. No additional panels required, no bevels. Just a flat door with a window, similar to the attached image. Surely there has to be a way to obtain this simple door with DoorBuilder - I just can't seem to figure it out. Every selection I'm provided with under 'Door Leaf > Leaf Style' that even comes close has an additional panel that I must insert.
Does anyone have any ideas?
3 Replies 3
No problem. Just use the single glazed door ( french door ) and adjust the size of the bottom rail to bring the bottom of the window to where you want it. See attached.
Gerald Hoffman
Archicad 4.55 - 29-Latest USA
Just choose a single paneled door (with glass panel) and increase the bottom rail dimension.
(Note to self - must work on Photoshop skills and speed)
Thanks - that's incredibly simple. I was stuck inside the box.
