DoorBuilder: Door with single window?
I've got this apparently bizarre requirement for DoorBuilder: a metal door with a single window. No additional panels required, no bevels. Just a flat door with a window, similar to the attached image. Surely there has to be a way to obtain this simple door with DoorBuilder - I just can't seem to figure it out. Every selection I'm provided with under 'Door Leaf > Leaf Style' that even comes close has an additional panel that I must insert.
Does anyone have any ideas?
Gerald Hoffman
No problem. Just use the single glazed door ( french door ) and adjust the size of the bottom rail to bring the bottom of the window to where you want it. See attached.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 27-6000 USA
2019 MacBook Pro-macOS 15.0 (64GB w/ AMD Radeon Pro 5600M GPU)
Just choose a single paneled door (with glass panel) and increase the bottom rail dimension.
(Note to self - must work on Photoshop skills and speed)
Thanks - that's incredibly simple. I was stuck inside the box.
