Doors duplicating when exporting to DWG
Here is a little problem I ran trough, everything seems fine in ArchiCAD but when exporting to AutoCAD using any translator setting The doors seem to double with different sizes (the picture is pretty clear on what happens).
Im using windows XP with AC 11 latest build and ACAD 2006.
Also, Anyone have preffered settings or method to output a DWG to be used by engineers (structural and mechanical)?
Any insight on the matter would be greatly appreciated. Thanks in advance.
Srinivas
Is the Trace reference on while exporting to AutoCAD?
ArchiCAD Services
ArchiCAD since v9 to latest
iMac, Windows 10
I could not remember if it was at the time but I just retried with Trace off and I had the same problem. Also, in AutoCad the two doors are toghether in one block, as if it was the same object when exporting.
