Doors locked in Schedule (List and Legend)
So my doors show up as locked in my door schedules so I can't edit them, but they are not locked on the floor plans, 3D, elevations, etc.. I've locked then unlocked all doors and individual doors using the Edit>Locking command, made sure all elements' layers including walls are visible and unlocked. I've rebuilt the legend and the list but all to no avail. They were unlocked previously and I was able to add text to the fields but can't now.
I've also tried quitting and restarting ArchiCad.
Thanks for the help.
1 REPLY 1
Check the layer combination that is saved with the schedule view.
If the layer is hidden the window will still show in the schedule but it will be locked, and the select in 2D/3D icons will be greyed out.
If the layer is locked then the window in the schedule will also be locked but the select in 2D/3D icons will be available.
So if you are using saved views to switch between your schedule and plan, this could be why your plan looks OK but the schedules is locked.
They may be using different layer combinations and some of the layers in your schedule may be hidden.
