Zendrix
Renovation status legend
Hi!
I have a schedule made up just to be a legend that translates what each colour is: yellow-to be demolished, grey-existing, red-new.
The thing is when i place the field "Renovation status" in the schedule, i dont get the "NEW" option in my schedule.
What am i missing?
Z
AC28 . LeNovo Y520 Intel Core i7-7700HQ @ 2.80GHz 8GB RAM. Windows 10 Home
1 Solution
Is the new element a wall?
Does the view for the schedule have a renovation status that is set to 'show all' ?
Go to post
4 Replies 4
Zendrix
Hi Barry. The project contains several NEW elements, such as Walls, slabs, etc. I used "wall" cause there is in the project "exisitng walls", "demolishing walls" and "new walls", so it would cover everything. (if i understood your question 🙂 ).
I didnt get your second question, but i think you mean the RENO filter i attach in the image? if so, it is overriding for both "to be demolished" and "new". (i have a feeling this is not what you meant).
* one print is the view, another is the view in the layout, where i also have the schedule.
Z
Zendrix
Found it, i got what you meant.
I had to click on modify sourve view on the schedule, and the reno filter was only showing demolitions. I didnt know the schedule itself had view options.. or is it regarding the layout where it is inserted?
Once again you save the day!
Z
Your schedule criteria is looking for 'all 3D elements' (I think) AND it must also be a wall.
You could just have the wall criteria.
The renovation status needs to be set to a renovation filter that will 'SHOW ALL ELEMENTS" or I guess because you want to see the override colours you can set it to use the 'overrides' as well.
Otherwise if the reno filter is set to hide new, then the new wall will simply not show in the schedule.
You should have a 'view' saved for the schedule and in the view settings you tell it what renovation filter to use - as well as layer combination scale, etc.
You need to make sure the schedule was opened with the correct renovation filter active, which is why it is best to open the schedule from the saved view.
