Read more
Export IFC Translation settings
ananas
is it possible to export IFC translation settings or only import them?
I have IFC translation settings  prepared as TPL file that I can import, but don´t know how was it made or exported from Archicad.
Anyone know or can link me
Operating system used: Windows 11 Pro 23H2
vlahtinen
It's not possible to export only IFC translators. Save the file containing the IFC translators you need normally as Archicad project (.pln) or template file (.tpl) using File → Save as. You can then import the translators to a different project from the saved file. You could also create a new empty file using a template, import the translators you want and then save the file as .pln or .tpl.
1 REPLY 1
vlahtinen
