2023-08-11 05:51 AM
Hi all,
Is there someway to export a skp file using the vectorial engine? Or some other way to export a white model with vector hatching? It is rather odd that the program does not actually just export what is in the 3D window...
Ling.
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
2023-08-11 07:10 AM
I have set the vectorial engine with monochrome and vectorial hatching on.
I can 'save as' in SKP format (in 25, I assume 26 and other versions are the same).
Can you not do that?
No idea what the results are as I don't have Sketchup.
2023-08-11 07:54 AM - edited 2023-08-11 07:55 AM
You can export, but it exports the same thing as if you had Simple Shading on, or any of the OGL options.
