Lingwisyer
Guru
Export: SKP w/ Vectorial Engine
Hi all,
Is there someway to export a skp file using the vectorial engine? Or some other way to export a white model with vector hatching? It is rather odd that the program does not actually just export what is in the 3D window...
Ling.
I have set the vectorial engine with monochrome and vectorial hatching on.
I can 'save as' in SKP format (in 25, I assume 26 and other versions are the same).
Can you not do that?
No idea what the results are as I don't have Sketchup.
Lingwisyer
Guru
You can export, but it exports the same thing as if you had Simple Shading on, or any of the OGL options.
