Export dimension to Autocad
how can I maintain the dimensions when I export them out to Autocad? They all turn out to be Line & text in Autocad.
When i open a dwg file in Archicad, i am given the option of opening the dimension from autocad as Line & Text or Single Dimension or Chain dimension.
Is there a setting in Archicad to do this?
thanks.
joanna
3 Replies 3
Aussie John
Joanna, check the "open options" in the translator. there are settings for dimension handling in there.
Cheers John
[/size]
Hi John,
I tried that out too. But when i export my pln, the translator does not have the Open Option. This Open Option only appears when i import dwg.
Will it take the settings I set eventhough it did not appear?
thanks,
joanna
Hi, Joanna
In the DXF_DWG translation setup window, onto save option settings , you have to choose SAVE LAYOUT ONTO: Paper space with cropped view;s content. If you choose model space, you'll have to explode the drawing in order to edit it, and it will explode dimensions also.
