2020-02-07 10:03 AM
 Solved! Go to Solution.
2020-02-10 09:10 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-02-10 09:10 PM
Minh Nguyen
GRAPHISOFT
2020-02-18 08:10 AM
mnguyen wrote:
Hi Ceren,
Thank you for sharing the issue and I am sorry about the experience!
With this problem, unfortunately, we haven't come across such a report yet. I believe this would need a closer look by our Technical Support team, but in order to help with the investigation, we will need a .PLA project file from you, where the error is present. It is highly preferred to provide a .PLA file so that the same Library Parts are within the file when we open it.
This way we are certain that the settings and other factors are the same for us as they are for you.
Additionally, could you please provide the translator that you are using to export the section to DWG? If you go to File > Interoperability > DXF-DWG > DXF-DWG Translation Setup, you can see where the translation is stored.
If you are willing to share the file with us, please reply either here within the post directly or through a PM and I will provide you a secure GRAPHISOFT link where you can upload your file to.
Look forward to hearing from you!
Best regards,
Minh
2020-02-18 09:44 AM
Minh Nguyen
GRAPHISOFT
2020-02-21 09:40 AM
Minh Nguyen
GRAPHISOFT
