‎2015-01-03 02:48 AM
‎2015-02-04 01:36 PM
‎2015-02-04 01:55 PM
‎2015-02-09 03:25 PM
‎2015-03-02 03:06 PM
zach wrote:I have noticed the same problem with exporting to Artlantis Studio. This is very uncomfortable if I need to merge only a part of geometry to Artlantis Studio file.
I have a serious problem exporting 3DS in ArchiCAD 18. When I need to export a part of my model I usually open the selected parts in the 3D view and save them as 3DS file. This always worked fine on all ArchiCAD versions and only the objects seen in the 3D window are converted to the 3DS file.
When I try this on ArchiCAD 18 it does not work well. 3DS file saved from the 3D window contains more objects than visible in the 3D window. Sometimes the whole model gets exported instead of the shown selection in 3D. Sometimes it works well when I open in 3D the same selection a number of times.
This is really annoying and I don't know how to fix it. Can someone help me?
‎2015-03-04 08:05 AM
‎2015-06-19 11:48 PM
KatalinBorszeki wrote:This is a terrible flaw in 18. It makes the whole export to 3ds so much cumbersome and it slows down the entire workflow, especially if there are many changes after the original export.
HI, this is a problem we have already heard from our users, it is planned to be fixed in ArchiCAD 19!
‎2015-07-02 04:28 PM
‎2017-06-30 11:30 AM
mallehk wrote:To eliminate scene flickering viewport clipping need to be enabled in 3ds Max's viewport settings, then move lower clipping slider slightly up:
But I have a scene where it still flickers even though I solve these issues above.
is there someone that can help me with one of my scenes to get this properly into 3ds max. Because I dont know what to change in AC to get this right.??
