2020-09-11 06:51 AM
2021-03-04 01:50 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2021-11-25 12:58 AM
Did you ever find a fix / work around for this issue? I've just discovered the same problem (Archicad 25 - Solo)
Thanks - Clare
2021-11-30 02:44 PM
Dear Clare,
Thank you for the question and I am very sorry for the experience!
Fortunately, we received some further information from another case. According to the developer, seems like before exporting to DWG, the DWG In-Out add-on uses an Internal API call which tries to check and update the drawings again, thus every drawing turns back into the "Needs Checking" status. But we are not sure why it happens to some files and doesn't happen to others. We will need to look into the API to check this.
The developer also mentioned that if the drawings have been updated before exporting to DWG, we can ignore this message as there won't be any changes in the model.
I hope this explains the situation, and once again, I am very sorry for the inconvenience! Please let me know if you have any questions!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
2021-12-08 12:56 PM
I have encountered the same problem. Not only do I get the error message when exporting DWGs, but when I import the DWG into AutoCAD to check it, the drawing only comes in as a block (with nothing in model space). When I try to import it into Revit the program says that there is no model space information, only 'viewport space' information. I am having to re-scale the block in AutoCAD to the correct scale and then save over my original DWG export!
I believe the issue has come from saving the project from Archicad 23 to 24. I am new to the software and did this by accident. When I down saved back to 23 I am no longer getting the error message but the DWG is still importing as a block in paper space and nothing is appearing in model space. - I have tried importing another DWG that was exported from the same Archicad drawing a while back and that appears in the model space - all okay. The bug has arrived and stayed since saving the 23 file to Archicad 24.
Jacob
2021-12-08 02:52 PM
Hi Jacob,
Thank you very much for the question!
In Archicad, for importing/exporting to DWG, we can control the output result by using the Translators. By default, there are several different translators for different purposes.
To answer your specific question, we can control how the model and layouts are exported to DWG through the option Save Layout into. To have the model drawn in Model space, make sure to choose
or
I hope this helps you with the problem. If there is anything unclear feel free to ask me again!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
2022-01-27 04:58 PM
So, i came back here, since i still have problems and it's nice to read it was kinda detected, but too bad it doesn't have a solution still.
2022-06-29 11:15 AM
I have encountered the same problem and I am sorry but I disagree with the developer when he says "we can ignore this message as there won't be any changes in the model", because that bag makes me feel very uncomfordable when expoting my final project and the program says that something may go wrong!
Looking forward for a proper solution!
2022-06-29 03:13 PM
and also, i don't know if it happens to you, but when using linked views from a BIMcloud file, linetypes scales are lost. So, of course, it's not ok this isn't yet solved
2022-07-27 04:34 PM
Hi Minh,
We do face the issue with CAD batch export (publish). And as you suggested above if we ignore the error message then CAD export are never correct. For example, if we publish CAD drawings of multiple sheets with merge option only one (first) layout gets exported in CAD and all other layout are blank and model space in CAD also does not show anything of remining layouts.
Can you please help us resolving this error. As we are facing this issue on large scale projects.
