We value your input!
Exporting STEP Files
JCCARLOS91
We are currently working with a fit-out company that is requesting for a STEP file format of our Archicad model. This is for them to fit their retail accessories into the the space while using our model as a base.
Is there a viewer or conversion software than can be used that can convert IFC or Autocad exports (Archicad) to STEP Files?
Looking forward to a quick response. Thank you!
John Carlos
AC25 | iMac 2019
If you search for "IFC to STEP converter" online, you will find many results, including online converters.
1 REPLY 1
