Exporting layers into numbers/excel
this was covered for archicad 8 here but i wanted to know if you can do the same for archicad 12
1 REPLY 1
SQL is there in AC12 too so I think you should be able to do it with the same long command that Karl provided in that other thread.
You have to go to the Work Environment Dialog and place the SQL command onto you menus so they are visible and can be used.
