Exporting through IFC
ratnabhirud
Hello,
I have problem in exporting IFC file from Archicad14 to Tekla Structures17.
Holes created in slab do not get recognized in Tekla.
I have attached an image showing actual slabs(grey ) in Archicad and Slabs in Tekla(green).
I have used default setting of Tekla translator in Archicad.
Does anyone know the solution for this problem?
Regards,
Ratna
AMD Ryzen 5 3600 6-Core Processor 3.59 GHz
Ram - 16.0 GB
System - Windows 10 Ultimate, 64 bit
NVEDIA GForce 8400GS
Archicad 9..., 24
11 REPLIES 11
Djordje
ARGH ...
Now SEOs go, but some objects don't ... it's under investigation ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Tekla Structures v17 have some limitations...
Info from help:
Openings, cuts and curved objects cannot be converted.
On v18 repaired only openings...
So loading a IFC model in Tekla is displayed correctly. But the holes, the final cut will disappear after the conversion.
Additionally, you have to consider the elements with slope and unusual! Most of them ends up in our trash ...
