Failed import of point cloud
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2022-07-27
08:17 AM
ā2023-11-30
02:07 AM
Hi!
I am trying to import a point cloud (E57) in a simple model, but Archicad fails and throws an error that I will try to translate to English:
"Failed inserting object of point cloud KRYSIEWICZA... Press NEXT to continue or Quit to abort."
The model was built in AC 25 POL version.
In most models my clouds get imported properly, but randomly a couple of models end up with this error.
The problem is clearly not about the point cloud file, because it gets improted properly to other Archicad models.
The issue is with this particular Archicad model (attached PLN). It cannot even import a small sample E57 file.
Here you will find some small sample E57 files:
http://www.libe57.org/data.html
What can be the reason of this problem and how can I solve it?
Certainly, I could hotlink or import geometries to a new, fresh Archicad model, import point clouds there and it would work, but I'm not interested in this solution, since it takes too much time with multiple broken models.
Windows 10
Solved! Go to Solution.
- Labels:
Data Exchange
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2022-07-27 09:07 AM - edited ā2022-07-27 09:45 AM
Hi Mike
You don't need import geometries to a new, fresh Archicad model or import point clouds there. You had selected the MISSING layer for the Object Tool before inserting !!! You just need to select the appropriate layer before inserting Point Cloud.
AC 8.1 - 27 INT/POL 3001
Win11 | Ryzen 5600 | 16 GB | GTX 1650
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Mike
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2022-07-27 09:09 AM
If it is not a problem with the point cloud, but is a problem with the file, then try opening the file with the "Open & Repair" option.
Close the file (leave Archicad running).
Now go to the FILE menu > OPEN > OPEN.
Browse for the file and tick the box to "Open & Repair".
I have no idea if it will actually work, but it can't do any harm - or at least it shouldn't.
Maybe make sure you have a backup of the file somewhere just in case.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2022-07-27 09:12 AM
You can find out for yourself because after a failed insertion you have an lcf file in the Library Manager. š
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2022-07-28 07:44 AM
Thank you all for your suggestions!
Fixing the file did not work, but choosing a layer for object tool DID š
I really think Archicad should consider that and describe the possible solution for this case in error prompt.
Windows 10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2023-02-21 07:51 PM
@Andrii Levko How about the following message I received regarding a point cloud file that I tried to import in ArchiCAD 26?:
AC 10-28 (Full)
Asus | 64 GB RAM | Windows 11
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2023-11-28 02:39 PM
Hi Mjules, I just completed this issue, AC25, .e57 file, the points amount was over the 280 mil limit, I had the guys who did the scan reduce the points per area & cut off some unnecessary data. Works good now!
