Failed to Create Excel file from Schedule.
After banging my head against the wall for about half an hour, I thought I'd put the question to you all to see if I was missing something easy.
I'm simply trying to save a copy of my window and door schedules to an excel file. It's important for my purposes to keep the formatting intact.
I've tried publishing with the result, "Publishing of the item failed because ArchiCAD was unable to generate it." I've tried "save as --> .xls" which successfully creates a file, however, the file is completely blank containing no information.
Publishing or "save as" to all the other options for file types works fine. any ideas?
Thanks in advance
8 REPLIES 8
Erika Epstein
Open the scheduler window so you see the schedule and then SAVE AS and choose the file format you want such as .doc or .xls.
Hope your head feels better soon
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Tried that, with the schedule open and refreshed. It successfully created the file but the file was empty. Strangely, all the other file formats work fine.
Thanks for the thought.
dom
Dom,
Your signature says you are on AC 13 Mac ... is it possible that you are actually on 14 now? Saving to XLS is a 14 Mac Java update bug reported (and patched) here:
http://www.archicadwiki.com/Bugs/CannotSavePdfAfterJavaUpdate
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Ha! Yes, just switched over once the hotfix came out.
All good now! Thanks Karl. This forum is the best.
Good news. Glad it worked, Dom! I give Graphisoft a lot of credit for how quickly they came out with the patches and the detailed Wiki article after the Apple Java update raised havoc for Mac users.
vistasp
Publishing as .xls just gave me the exact same error that Dom got.
Was Save As XLS introduced in 14? My only options - with the schedule window open - seem to be .txt (tabbed), .dxf (huh?) and .pdf.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
I seem to be having the same issue with AC 16 can anyone help.
