Fileformat other than IFC to export to Autodesk Revit?
Hi, my questian is:
Is it any format i can export my Archicad files that dont lose any geometric data?
DWG, is it any problem with exportin to this format?
Im told that IFC needs a addin to be exportet the corect way but also missing some element when its exported.
1 Solution
[email protected] wrote:
I am told that the IFC works well as long as it does not contain trimmed geometry. Do you know if there is any solution to this?
It's false you only had to use the good parameters
Will the Dwg format only be possible export format for Autocad?
DWG, DXF and DWF too (like ifc you had to use the good parameters
Have you used "IFC Model Exchange" before? I have read that this supplement will work well for export of IFC.
Yes but I always got better results by setting myself my export ifc according to my needs (import and export)
For those who do not want to look at the subject it remains a partially relevant solution since it is not specific to a project and its needs
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
Go to post
3 Replies 3
ifc export from Archicad to Revit do not lose any geometry data if you correctly set the export translator ifc and if the Revit user knows how to use an ifc correctly (import translator)
If you only want geometry you can export a :
- fbx file by the twinmotion export
- 3ds file by the goodies plugin (Download Goodies for ARCHICAD)
Christophe - FRANCE
Archicad 15 to 29
Thanks for the quick reply
Christophe - FRANCE
Archicad 15 to 29
