Getting things to NOT schedule?
Ivan Myers
I need some columns to not schedule. I have listed the "Full ID" as OMIT and told the scheduler to NOT list ID's with the word OMIT, I've even tried changing its "Element Classification" to something other than a Column.
They still end up on the Column schedule.
What is the trick?
Thanks
Ivan
Designer/ Drafter
ArchiCAD 26 on 27" Mac
Can you show a screen shot of your schedule criteria?
It may be easier to work out what the problem is.
Ivan Myers
Hi sorry for the late reply. I think I got it solved a while ago by learning a bit more of how the scheduler works and how the parameters work. Thanks though.
Designer/ Drafter
