Thank you Karl, again...it worked.
Process as follows:
1 Open AC14 as well as Google Earth (GE)
2 In GE, zoom to the site, expanded to include the necessary context.
3 In GE, File>Save>Save Image (for color jpg). Should create a new folder for the image(s) as well as for an exported Linked Library (to be created described in the following steps).
4 Without moving the point of view in GE, back in AC select File>GE Connections>Snapshot.
5 Place snapshot in the Story window (model area plan view). Note that an object is created with a black and white aerial image mapped onto it.
6 In AC Library Manager, a new Embedded Library 'Google Earth' is automatically added. Select the GE Embedded Library and export a Linked Library to the folder you created in step 3.
7 In Mac Finder or Window's Explorer, browse to the exported GE Linked Library and overwrite the black & white JPG file(s) with the separately saved color JPG.
8 Back in the Library Manager in AC, Add the modified GE Linked Library and delete the GE Embedded Library.
With the exception of the scale being haywire, everything else should look pretty good.
Note that the above process assumes you have downloaded and installed Google Earth as well as the GE add-on for AC, available for Windows only (D'oh!).
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
