onkey89
Graphic Overrides
I’m a new user of Archicad. I recently stumbled on the graphic overrides setting but it only allows me to use graphic overrides in the model space of the drawing but when I place a drawing onto a layout, it reverts away from the graphic overrides. Anyone know how to change this?
3 Replies 3
@onkey89 , read these pages and they will give you an overview of the process
AC 29 INT 4006/WIN 11
hevi
Ace
You need to redefine the View.
Either right click on the View in the View Map > View Settings > Graphic Override and change it to the saved combination you want to use.
Or right click on the View in the View Map > Redefine with Current Window Settings but note that this will redefine the View for all settings that differ between the Window and the View.
Rubia Torres
Hi @onkey89. Welcome on-board!
You need to change the settings of the view which you want to place/have placed in the layout.
In the View Settings dialog, go to Graphic Override and assign the desired one, then save it. Back in the layout, update the drawing (right-click > update).
I hope this helps 😉
Rubia Torres
Community Expert | GRAPHISOFT SE
Did you get a helpful answer on the forum?
Give it back to the Community by marking it as an accepted solution!
