You need to Install the PlugIn for AC and you need to install the Import PlugIn for C4D.
In AC when you export the file select 39.37 as your scale factor.
To Import the Geometry in C4D you have to go under the PlugIns -> Import AC.
The advantage of using this plugin is that if your model changes then you can update it without having to reapply all the materials.
Do a search in the forums for more info.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08Mac Studio M4 Max 64GB ram, OS X 10.XX latest
