HELP!!! Archicad to cinema 4d export units Scaling
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2010-07-09 03:42 AM
2010-07-09
03:42 AM
i have e cube 200x200x200 feet in cinema and one with the same size in archicad for comparison and no matter the combination of scales I do they don't match please help me!!!!!
Labels:
- Labels:
Data Exchange
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-07-09 03:32 PM
2010-07-09
03:32 PM
One option is to scale the AC export using 39.37 in Cinema. Apparently changing the export scale in 3DS format does not do anything in AC. This is a Bug
You can download this plugin which works perfectly and you can specify the 39.37 factor in it.
http://dinnye.neobase.hu/content/downloads
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
AC28 US/INT -> AC08
another Moderator
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-07-09 03:37 PM
2010-07-09
03:37 PM
does it work the same with Cinema, what number should I put on the archicad options geometry scaling, when saving as .ac4d, and what on the import in C4D.. thank you so much for your help!!!
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-07-09 03:52 PM
2010-07-09
03:52 PM
You need to Install the PlugIn for AC and you need to install the Import PlugIn for C4D.
In AC when you export the file select 39.37 as your scale factor.
To Import the Geometry in C4D you have to go under the PlugIns -> Import AC.
The advantage of using this plugin is that if your model changes then you can update it without having to reapply all the materials.
Do a search in the forums for more info.
AC28 US/INT -> AC08
AC28 US/INT -> AC08
another Moderator
