HELP!!! Archicad to cinema 4d export units Scaling
need some help getting this to work, set up my units in archicad to feet, I do the same in cinema, then in archicad I do save as and it ask me for the geometry scaling, I've tried every combination an the model does not comes in to scale in cinema. could some body give the work flow on this.
i have e cube 200x200x200 feet in cinema and one with the same size in archicad for comparison and no matter the combination of scales I do they don't match please help me!!!!!
3 Replies 3
Eduardo Rolon
One option is to scale the AC export using 39.37 in Cinema. Apparently changing the export scale in 3DS format does not do anything in AC. This is a Bug
You can download this plugin which works perfectly and you can specify the 39.37 factor in it.
http://dinnye.neobase.hu/content/downloads
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
does it work the same with Cinema, what number should I put on the archicad options geometry scaling, when saving as .ac4d, and what on the import in C4D.. thank you so much for your help!!!
Eduardo Rolon
You need to Install the PlugIn for AC and you need to install the Import PlugIn for C4D.
In AC when you export the file select 39.37 as your scale factor.
To Import the Geometry in C4D you have to go under the PlugIns -> Import AC.
The advantage of using this plugin is that if your model changes then you can update it without having to reapply all the materials.
Do a search in the forums for more info.
AC29 US/INT -> AC08
