Help file
I am from Brazil (sorry for my bad english)
I am trying to help a girl friend. She uses AC 9 and dont read english.
I read english (so so) and I would like to translate a part of help about the convertion DXF/DWG to AC because she works with AutoCAD users and have many problems when projects come back and she missed all the objects (walls , windows, doors).
I dont want to tell to her until I finish the translation. ( Its a surprise) .
But I dont have the help file. In the web I got a PDF file and in it a read this part:
For full details, see the DXF/DWG Conversion Guide in
the More Information section of Chapter 9: Collaboration and
Connectivity in ArchiCAD Help.
I think I need only this part. If somebody could send to me this part of the help file I like so much.
my address is : [email protected]
Thanks for your time.
Joao
2 Replies 2
Ben Odonnell
Joao,
You can find all the help files, which are html documents in your ArchiCAD 9 \Help\ArchiCAD folder, ther is also a folder for Plotmaker help.
You will also find a folder in there called "files", which contains the whole help menu in html format.
HTH.
Cheers.
Ben
Ben O'Donnell
The complete ArchiCAD 9 Help is on the web:
http://download.graphisoft.com/ftp/publishing/ac9_help/wwhelp/wwhimpl/js/html/wwhelp.htm
