How do I set up my own style sheet [for Project Reviewer..]?
fhedberg
Just wondering if anyone has any information on how to create your own style sheet for publishing a set of drawings with the project reviwer Web environment ???
Or if you could point me in the right direction...
thnx
Fred
W11 Home | ArchiCAD 27 3001 AUS FULL
I use several tools…basically it’s a combination of changing what’s in the C:\Program Files\Graphisoft\ArchiCAD 9\Publisher_Reviewer folder….keep in mind that it draws from the folder Reviewer….so you have html, xml, and java….the tools for that are the following…and they are free
Html Kit by Chami.com
http://www.chami.com/
Peter’s XML Editor
http://www.iol.ie/~pxe/
fhedberg
Thnx, I'll give it a try....
